2003 Disco Abs Modulator
pjvarc
question, last year i repaired my ABS Modulator with part no SWO 500030 a land rover OEM repair kit. a year and two weeks later my brake light came. the dealer is charging for a new shutter valve $1,047. any thoughts on doing the band aid approach again? or biting the bullet and paying $1,047.
repair kit was only $90 however, i did notice throughout the year a my abs chiming away with two tones only every now and then. the light came on this week.
Did you do the work yourself? If so, when you removed the old switch assembly was there break fluid on it? If so the Modulator is bad, if not then the odds are you have another problem.
pjvarc
thanks for replying. no i did not do the work myself took to a mechanic. my brake light came on after three chimes and stayed on. was advised abs mod needs to be replace
i found this site last night ,http://www.robisonservice.com/articles/ronr_aug2006.asp
last year i had the brake light come on and a different mechanic simply sold me on a repair kit from land rover. i guess i may just bite it and do the job it and resolve the issue.
STQAddie91
