Mark Larocca
My guess this has come up. But as a LR3-LR4 and Disco 5 owner and now the RR 5.0 the more info the better. If you have anything with the 5,0 supercharger more than likely you'll have coolant leaks and potentially a blown fitting or dry rot pipe. So before you burn up a 30K motor make sure to inspect the piping and connections. My thermostat blew and luckily I did not overheat the motor. I was told some of the higher optioned Range Rovers have two thermostats. Land Rover makes a full hose kit and new aluminum "Y" pipes are available. You should also service the super charger if you're doing this service. Make sure to pay attention to these items. My 2018 only had 36K so I figured I had time.. NOPE...
