99 discovery coolant leak
G
goat
looking for help , have a apparent coolant leak pooling in the valley under intake on the 4.0 how tough a job to repair ? Will adding a can of stop leak to temporarily repair hurt anything. I was able to get a wrench on some of the intake bolts and got almost a full turn on a couple left side rear
I wouldn't add stop leak to the radiator of a Disco (way too many people complain of overheating as it is). Sounds like just the intake gasket is bad. How hard depends on how good a mechanic you are...? If you hate changing plugs and wires, take it to just about any shop (just take the gaskets with you) if you feel comfortable changing lets say the brakes and rotors then you should be fine. figure about 3 hours worth of work for a good mechanic... about 6 hours or so for someone who has never done it.
Vincentvip
