Air Spring reseal kit (LR016412)
John Higgins
San Diego, CA
I recently replaced my front struts and reused the air springs as they were in good shape. The reseal kit came with 2 large o-rings that fit around the outside of the collar that mates the strut to the bag.
That collar has 2 more inner o-rings that I had to re-use.
Anyway - looks like I've introduced a leak into the system and I suspect it's the 2 large inner o-rings. I'm about to pull the struts and redo them but unsure where to source the extra o-rings from.
Just curious if anyone else has done this and had any luck?
renli3d
Seattle
What I've done in the past to great success is soak used o-rings in AT-205. I recommend doing it for at least several hours. It restored their flexibility and you can re-use them as long as they're not torn.
