AJ126 torque etc specs
leftlanetruckin
Missouri USA
Hey guys
Yes I've tried searching, but it's either contradictory numbers, or they had bolts made.
Rebuilding an AJ126 due to a stuck injector....Pulled a head to remove it safely, saw some minor cylinder scuffing that needed honing out, so engine got tore down. It's a "while I'm in here" kind of deal
I'm looking for torque specs and sequence for the bottom end. Main bearings, clearances on Plastigauge, end play on crank. The rest is covered in Alldata.
I have some ARP rod bolts coming, that are from a BMW, so I can follow their guidelines for those.
Block should be back from machine shop this week, so looking at getting it back together soon
Thanks!
Martin
