Front caliper carrier bolt torque specs
Makepiepls
Seattle
Hey folks,
Just got done with a front end brake job and I am finding conflicting information about the main carrier 21mm 12 point bolt torque specs.
I found references on the forum to 203 ft lbs and also 85 ft lbs
Anyone know what the right spec is for a 2014 LR4?
Thanks in advance!
Makepiepls
Seattle
Thank you! 202 ft lbs it is.
The only hard part was swapping out the brake pad sensor. I had to partly remove the wheel liner so I could reach behind and swap them out. Not easy but can be done without taking the wheel liner off totally if you are agile anyway. The old sensor wire was torn I guess from junk in the road maybe or age from 2014 to 2026.
