Alignment with Coopers...
zbysiu23
I have the Zeons 285/60 for a while now, I went to the dealers the other day in order to do the alignment....well I was told that because of the tire size and the thread design they are unable to attach their alignment equipement and the only way to do it would be to swap set of wheels with stock tires from another LR3 and do the alignment???????
with an extra cost of course.....
I have never heard of such a problem?????
buddaman
I have michelin 285-60-18 and the dealer aligned them with no problems
zbysiu23
Well I have the specs for alignment always in my car, the thread on zeons protrudes a bit, yet ..I guess this dealermust have only the "city" version of alignment equipement since I had been aligning wheels on my jeeps with some biggies on them...I will do it elsewhere..I guess...
Boaz
If you got your Coopers at a good shop, they should be able to do it for you at a discount to what you'd pay at a dealer anyway. I found that the Coopers, being so big and heavy (~50 lbs each), were harder to get balanced right the first time I had them put on. America's Tire was great about redoing it 3 times to get it right. Haven't needed an alignment adjustment yet though.
drzjoint
You want your alignment done with your tires not oem go somewhere else
ChuckD
Aren't you supposed to "lock" the suspension via dealer's computer to get proper alignment?
ChuckD
buddaman
I thought so to. thats what my land rover service rep told me
CoMclovin
Yes, the dealer or shop doing your alignment should put the truck into "tight tolerance" mode, prior to performing the alignment. Some shops actually outsource the alignments to a local shop, so you may ask your dealer if they do.
zbysiu23
well what is the "tight tolerance" ??? I know the new specs...what else is different from the routine alignment????
Place vehicle in "tight tolerance"
mode using IDS and align suspension
geometry
57.65.04 1.80 W6 ALGN4W
Normal warranty policy and procedures apply.
REPAIR PROCEDURE
ALIGN SUSPENSION GEOMETRY
1. If the vehicle has Electronic Air Suspension (EAS), refer to Technical Bulletin LA204-007, connect IDS to the vehicle and place the Electronic Air Suspension (EAS), into "tight tolerance" geometry setting mode.
TOE ADJUSTMENT
TARGET
SPECIFICATIONS
(decimal degrees)
Front total toe + 0.03
Left-hand rear toe + 0.18
Right-hand rear toe + 0.18
Rear total toe + 0.36
zbysiu23
..still do not get it why the LR dealer could not do it with 285/60 Zeons and non LR shop would be able to do the alignment??????
MArsel
