Attention all Roverphiles - What is a healthy Land Rover
M
Mark
:hmmmm:
I have the Actron CP9145 OBDII scanner I got from amazon.com ($200.00) and one of the features that intrigued me was real-time data collection.
Now for the forum test:
Given the following inputs/outputs, what would be the proper/correct 'healthy' number?
1. Absolute Throttle Position (%)
2. Idle (RPM)
3. Calculated Load (%)
4. MAF (LB/Min)
5. Coolant (F)
6. Intake Air Temperature (F)
7. Ignition Advance (Degree)
8. Secondary Air Given as Atmosphere
9. Long Term Fuel Trim (1) (%)
10. Short Term Fuel Trim (1) (%)
11. Long Term Fuel Trim (2) (%)
12. Short Term Fuel Trim (2) (%)
13. Fuel System 1 Given as CLOSED
14. Fuel System 2 Given as CLOSED
15. O2 Sensor Output Voltage (Bank 1 / Sensor 1) (V)
16. Short Term Fuel Trim Bank 11 (%)
17. O2 Sensor Output Voltage (Bank 1 / Sensor 2) (V)
18. O2 Sensor Output Voltage (Bank 2 / Sensor 1) (%)
19. Short Term Fuel Trim Bank 21 (%)
20. O2 Sensor Output Voltage (Bank 2 / Sensor 2) (V)
On the Oxygen Sensors my values were around .7 - .9 with an occasional drop below the magic .5 number. One sensor is staying mainly below the .5 number (I Think, since the 4 line screen does not have the O2 Sensors on the same screen).
P.S. The Actron scanner is available from amazon.com until 30 June for the ridiculous price of $184.00
M
Mark
No Takers?????
Hey, I know this is tough, but, what the hey!!!!
Someone,somewhere, somehow should know this answer.
The Actron has feedback capability, but what good is the information if the user cannot interpret.
D
disco1
The best place to get the optimum outputs is from a LR test book. Your local/nearest dealer or independant might oblige.
M
Mark
Possible Answer
I was talking with LR Dealership the other day and asked about my question and what would be a 'healthy' rover. He suggested that I had the answer all the time.
The answer was right there in front of me.
What I will need to do is collect the data over a period of time and when a code is thrown, collect the data and compare against the running data. Then I will know which data was changed. It will require some work, but I think it will be useful in the long run.
I will post an average of the values in the first post in a few weeks just for reference. I a code is thrown, then I will post the change.
Sorry about the tough question!!!
M
mkosloffsky
Healthy Landrover ???
Healthy Landrover is an oxymoron..
STQAddie91
