Battery
97rover
Does anyone know if the battery in my 1997 Disco 4.0 will fit in my 1997 Range Rover 4.0 the reason being is the battery for Disco is cheaper than the Range Rover 25 cold cranking amps different.
Should fit.
97rover
Found out that the battery for Disco is only smaller in size so that it can fit in battery housing. Cold cranking amps are more in the Disco than that of the Range but will still do the job. Just made a bracket for the Range Rover. The battery for the Diso is about $30.00 cheaper here. Checked 4 different locations all about the same.
