Bluetooth Module on LR4 2011
Hsiu1985
Barcelona
The module is in the right rear cargo area, tucked behind the trim beneath where your second row seat belt retracts. You'll need to unclip the side trim starting from the tailgate to get at it. Before swapping it out though, try pulling fuses 68, 67, and 64 in the passenger fuse box—that reset worked for a bunch of owners I've heard from. If that doesn't help and you need to replace it, the module is a straight swap with no reprogramming needed, which makes it pretty straightforward for a DIYer.
WandWover
