Brake Caliper 97 Disco
skinnydipper
I'm leaking some fluid on the right front. I'ts not the hose. Is there such a thing as a caliper rebuild kit or do I gotta buy new?
You can rebuild, but for the price I would just buy a new one.
You can go to Atlantic British or Rover Connection and buy a kit, a rebuilt or a new one, just remember, because it is a front caliper leaking, you will want to do both because usually if only one is done, it will pull.
Maddie
Replaced both rotors and pads but one caliper mine doesn't pull. I wouldn't replace both if one froze up like mine did. I'm safe but on the cheap.
skinnydipper
Thanks - I just replaced the right front today. Drained and replaced the fluid from the whole system, all is good again.
