Can somebody please help asap on my 2003 LR Disco SE
LRTECH
check your Mass Air Flow Sensor. It's bolted to your intake hose right after the air cleaner box. if that gets dirty or goes bad you will have a crappy running vehicle. they make a MAF cleaner. I would spend the 6 bucks to clean it to see if that fixes the problem.
jboyd000
Thanks man ill try that. The only thing I haven't REPLACED is the maf,o2 sensor and a coil pack. Do u know of anything else? Thanks for your help by the way!
Spiderfreak80
You can pick up a code reader on Amazon for as little as 25 bucks for stuff like this. It will give you the code and then just do a search on the forums for the code. It will also let you clear the code when done.
Have the Codes read before you start through parts at it... could just be your gas cap is loose.
Why are you asking us to guess when you haven't even had the codes read. Get the 4 digit fault code numbers read and get back to us. In the mean time, quit driving it unless you want to burn your cats.
PE_in_UAE
