Changing Steering gear box..
audioclay
Has anyone been down this road with an 03 disco? I have the parts and the manual and I have been in over under my truck quite a bit. Are there anythings to watch out for? Any suggestions???
Chongo
It's pretty straight forward
Just like the title says, it' is pretty straight forward. You don't need to separate the drag link from the steering box arm, just separate the arm from the box, then the hoses and steering column at the box, then the mounting bolts through the frame / chassis. Then reverse the procedure to install. You’ll need to add fluid to the unit before you start it up. the Drag link adjustment sleeve is how the final adjustments are made to center the steering wheel.....................Good luck……… Chongo
:bandit:
