Could I use this for my school project?
JoshuaNU
I've just stubled upon this site www.holdenhistory.com, could I just copy the technical
data from the site or do I need special permission?. I'm doing a school project.
Joshua
Rix92x
:albertein
Joshua
Josh,
Not sure what grade or year you are in school...however, any time you use a source for information you must cite it correctly in yoru research or your paper. There are several resources to use that will demonstrate how to cite information you take from an internet source. In most cases, as long as you cite the source, you may use the information.
Failure to cite your sources could not only cause you a failing grade on your paper, you could also fail a whole course or be asked to leave a course for plagiarism.
Good luck on the project
Sid1577
