Courtesy flood Lights
cbillin
The driver and front passenger door courtesy flood light on my 2011 LR4 are not working. I have checked the fuses I believe would be controlled by these but cannot get them to come on. Any suggestions? I recently put LED bulbs in and this is when it stopped working. I replaced it with the old bulb and still did not work so it is not just the LED.
tlt
Mostly likely a plug unplugged...
billj214
Had same issues, LED I had was bad and caused power to shut off to bulb. I replaced with regular bulb and after 15m it came back on, then put another good LED in and worked. LEDs are polarity sensitive so try installing in both directions.
Sent from my XT1254 using Tapatalk
