Customer replaceable tail lights or signal light
mtbutler93
Is it possible for a customer/owner to replace tail lights or a signal light?
If so how, and what parts do i need?
Thanks,
are you talking about changing a light bulb? ...or do you mean getting a new design installed? Either way the answer is "yes."
grommet
Instructions are in your owner's manual. For parts, visit your local automotive shop or your LR parts counter... and they'll set you up. If you are talking not just the bulb, you'll need to stick with the LR parts counter. :)
mtbutler93
thanks, just replacing bulb on rear, will check the manual and go to the LR parts desk
no need to go to LR Parts desk...unless you like to throw away money.
Just go to your local auto parts store, look up the replacement bulb, and pay the $2.99 for the pair of bulbs...takes 10 minutes to replace.
I actually stocked up on those bulbs...they are the same for many of the luminaires in that assembly and they're cheap. PLUS, they go out quite often as it turns out...
