Disco 11 rear park light does not work
R
rovering
Greetings,
On my 2001 SE7 I noticed that my right rear park light was not lit and assumed the bulb was blown. I replaced the single filament with a like sylvania bulb as specified. It still did not work. I checked the fuse box in the engine compartment. The related fuse appears to be a 30 amp fuse at the extreme rear left corner (standing in front of the vehicle). The fuse appears to be ok as it worked when I switched it to the Horn position. I am not certain where to go from here. All the wire connection/harness seems to be fastened properly. Has anyone had a similar experience and what was the solution? Thanks for your help in trouble shooting this problem.
Did you clean the offending bulb plug? Then tend to build up junk or even rust in some cases. Check with a volt meter to see if you getting voltage.
R
rovering
Joey,
Thanks. I got it resolved using a second bulb (first was defective) and cleaning the contact area.
STQAddie91
