disco 97 transmission problem
ysaga
I can shift from park ,the transmission was working fine ,no noise no sliping please advised ??
whiskeynipple
make sure the brake safty is disengaging - you can hear it if you listen close to the shifter and press the break (with vehicle on)
if not check the break pedal triggers
also make sure the linkage (under the truck on the passenger side of the tranny) is still connected... my cotter pin rusted out and I couldnt shift out of gear when my poped out... 37 cent fix!)
ysaga
Thank you
I decide to take the car to the dealer and you was right was the brake switch ,your replay was to late
Thank you
PE_in_UAE
