Do I have Bluetooth?
A richardson
Derbyshire
Hi
I have a 2007/2008 tdv8. It's loaded with gadgets but not sure if it has Bluetooth. If I press the phone button it just says no phone fitted. Can anyone help?if I doesn't have it is there an upgrade or conversion kit?also I get TV but the signal breaks can that be improved too?thanks
grrinsman
Chicago
It should have Bluetooth for receiving and making calls. You will need to pair your phone with it. The pairing code that I had used I think was 2121. It may be in your owners manual. If not try YouTube. Good luck.
A richardson
Derbyshire
Thanks...I've seen the bit about pairing and the pin 2121 but no idea how to do it...nothing in the manual either suggesting maybe I don't have it?
grrinsman
Chicago
If you have an iphone...
1. You need to make sure that you have turned on the Bluetooth in your phone's settings.
2. once you are in your vehicle use your phone to search for other devices
Let me know if this seems to work.
PE_in_UAE
