Don't put a OBD scanner Bluetooth driving
Florida.
To help other owner
Is cool to know with your tablet at the dashboard at the top of the GPS what is happening in your car using those OBD Bluetooth scan with the torq app.
The thing is i discovered with the time if you drive with this all the time connected to the OBD without reason the LR3 pull a out the false code of SYSTEM FAULT SPECIAL PROGRAMS NOT AVAILABLE and down in suspension. apparently the OBD Bluetooth stop communication or maybe interrupted the communication with a couple computer andboard showing this code
To fix the problem dont drive with the OBD scan Bluetooth.. Good luck
