fuse? sunroof/fog lights/cruise control
T
tony
The following items aren't working on my 95 County LWB. I was hoping someone could enlighten me as to whether they could be common to a fuse perhaps?
Sunroof
Fog Lights
Cruise Control
G
Geolander
I have much the same, sunroof wont close properly, have to apply force from top, fog lights-only one works while other is intermittent, and cruise is **** (replace all but the ECU)
Moose
Cruise control -- check the vacuum lines in the engine bay, if they have cracks in them the cruise won't work. Another thing to check is the switch located on the brake pedal.
Sunroof -- is it not working at all or just not closing correctly?
Fogs -- could be a number of things, including a switch (most likely), burned out bulbs :biggrin:, or shoddy wiring/ground somewhere.
N
NIMO1
Hi, new owner of 93 RR County and have noticed similiar issues. My first thought is to change out all the fuses and work my way down from there. Is this a good idea? My fear is that changing ALL the fuses might create a new problem.
Hae79547
