2014 RRS L494: JLR SDD Ignition Won't Stay in Position 2 - Session Crashed during "Current vehicle car configuration modification"
nikola
Serbia
Hi, I have fully charged the main battery with an industrial charger and even bought a brand new battery to be sure. The auxiliary battery is also confirmed at full charge. I have also performed a hard reset by touching the terminals together to discharge the system, but the problem remains.
What happened:
I was using JLR SDD and entered the function: "Car configuration management - Current vehicle car configuration modification." While the process was running, the last message I saw on the screen was "Communicating with the Gateway Module (GWM)"—at that exact second, the car just powered off everything. The session hung and never recovered.
What the car is doing now:
  • The Power Drop: When I press the start button, the dash lights up with a million errors and then the power drops. It stays on for 0 to 10 seconds before the latch clicks and kills all power.
  • The Lockout: If the power drops, I cannot try again immediately. Even with the keyfob against the steering column, it won't react; I have to wait a few minutes before the car will even attempt to wake up again.
  • The Random Start: Interestingly, after the car sat for about 2 hours, I was actually able to get the engine to start briefly, but then the power dropped again and it turned off inside that time frame from 0 to 10 seconds.
  • Frozen Steering: The steering wheel is extremely heavy/hard to move because the rack isn't getting a wake-up signal.
  • Park Lock: I had to use the emergency red strap just to get it into Neutral and tow it.
The Situation with the Dealer: The car has been at British Motors for 5 days. They claim they "can't move the car" and haven't made any progress. I don’t know exactly how they are treating it (perhaps as a hardware failure), but they haven't given me any real info. I am certain it is a software brick caused by SDD hanging during that GWM communication.
The Question:
  1. How do I force the car to stay in Position 2 when it's in this "Death Loop"?
  2. Does the fact that it started once after sitting for 2 hours suggest a specific "pending" or "watchdog" state in the GWM?
  3. How do you force an As-Built flash via SDD when the ignition won't stay latched?
  4. What should I tell the dealership? Since 5 working days have passed with no progress, it suggests they haven't even attempted a manual recovery. Is there a specific technical term or procedure I should demand they try?
I apologies for longer post but i really need help since I am stuck. I do no have any screenshots since car is at British motors.
Rover Range
Texas
Try disconnecting the battery for 30min.
If that doesn't work, the body and keyless modules will have to be replaced. You will need two key fobs for that procedure.
nikola
Serbia
Thanks for the input, tried that with battery. I have ruled out physical hardware failure as the car was perfect until the software hang. As I wrote:
'The Random Start: Interestingly, after the car sat for about 2 hours, I was actually able to get the engine to start briefly, but then the power dropped again and it turned off inside that time frame from 0 to 10 seconds.'
Rover Range
Texas
The dealership may be able to recover the corrupted modules.
They have to run the immobilization procedure to get the module communications active.
VelarSupercharged
