Gap iiD question
Frank8
Vermont
just bought the diagnostic tool and have been browsing my LR4. I cannot find anywhere the Tire Pressure Monitoring Systems Fault so that I can turn it off.
It doesn't show up on the faults list
Where do I find it?
Thanks
Frank
AxelR
You can turn off the TPMS with the tool. Just don't look under fault...
Frank8
Vermont
Ok, now I know where not to look. But where do I look to find it? I've scrolled thru every part and don't see it unless it's called something else
What is it called and where is it?
Frank
AxelR
Google search (or other search engine) links to the Gap Diagnostic FAQ page. Pretty simple to use.
Otherwise check the CCF on your tool.
Car config > Read the CCF > BCM - Body Control > Tire Pressure Monitoring 1 and 2 > Switch to "None" (make a note of the default values before scrolling to None, just in case you'd like to re-enable TPMS in the future, as there are many listed), exit and follow instructions to write/update the CCF. You will need to reset certain settings after rewriting the CCF, such as date and time, pick Fahrenheit or Celsius, etc.
Frank8
Vermont
Many thnx, Umbertob. The Gap manual wasn't much help but I muddled about and finally found tire pressure 1 and 2. I changed to "none" but like a **** didn't record the original options.the light is out now but I would like, sometime , to activate the sensors and I'll let the dealer do it at the first service in about 3k miles.
I've never used a diagnostic tool before so this is all new to me and I appreciate you laying out the sequence,
Frank
