High idle switch
Crunchy When Wet
Anyone know of a company that makes a high idle switch for the LR3? I would like a switch to up the rpms to about 3000rpm from idle.
No, I don't.
Why on Earth would you want to do that?
bbyer
Alberta
a bigger alternator also perhaps
I would be looking for sites such as below that specialize in high output alternators for police type vehicles.
Given that our electrical system is Ford designed, it may be that something Ford like can be adapted to provide high idle.
It seems high idle systems, rather than just using a cable pull knob, now instead electrically communicate with the ECM that then tells the engine to rev up via the cruise control buttons. Increased engine rpm will then enable the alternator to put out more amps assuming the alternator has the cooling capacity.
http://www.nationsautoelectric.com/highoutput.html
PE_in_UAE
