How to reset the Brake Pads "worn" Alert light on 2015 Range Rover Supercharged
Robert B
DFW
Just replaced the brake pads and sensors on my 2015 Range Rover and I can't find how to reset the brake pad senor worn Alert ....????
Help....:)
Unless something has changed, if you have replaced the sensor that was broken (setting the light to on) then it should go off. It shouldn't require intervention.
Basically if the sensor wire is broken it sets the light to "On", i.e. not what you want since it will stay "On" until your replace the sensor wire that was broken. If you tried to reuse any of the sensor wires it may have gotten broke causing the light to stay "On". To turn the light "Off" it should just be a matter of replacing the sensor wires.
rsauer
Help....:)
I swapped pads only recently, belaying the full monty of rotors etc. was able to save the existing sensors, I disconnected the battery for a few minutes and the pad light went off and has remained off
jrza101
Evanston, WY
As I understand it, if the sensor goes off it’s pretty much done for and needs to be replaced. I just replaced mine, sensor included, and the light went off on its own.
Whtmustang
Canada
Hey Guys! If you guys have trouble with that brake light, and message is saying check pads, I made a video on youtube recently dealing with that. It was on a 2011LR
Please watch and subscribe! Hope it helps.
Resetting the Brake Warning Light
