L320 CD Navigation Unit problem
Trenneck
2011 Range Rover Sport HSE 85,000 miles. Navigation screen is black and in dash cd player will not accept disk. Vehicle runs and drives perfectly. OBD code UO184 which is lost communication with radio. First day of problem the screen briefly flashed the Land Rover start up logo a few times. All fuses check out ok. Pulled nav screen unit and cd/nav unit, checked connections at dash. No radio. Android phone connects to radio via bluetooth, but no bluetooth connection to vehicle phone. No response so far, assuming a short or ground fault, or bad cd/nav unit due to not accepting disk and lost OBD connection error. Any thoughts prior to taking in for service $$$$$ would be appreciated.
AztroRover
California
Try the old-fashion disconnect battery, wait 15 min, reconnect see if that fixes it. Kinda a hard-reset. Years ago, mine went out. Reset fixed it. Been like 5 years and hasn't happens again. Gremlin most likely. Course since you dug into yours make sure you put it all back together right. Good Luck!
tsgolf
Arkansas
Sounds line the MOST fiber optic issue. There are several youtube DYI procedures to use a bypass and figure out which unit is causing the breakdown.
