low coolant
horns
Would appreciate some input.
I have a 2012 LR4 w/ 47K miles on it.
When it was still under warranty I had the water pump placed (I would guess at around 20K miles). The initial issue was low coolant at that time.
Today I find that the truck is again low on coolant. I need some thoughts on filling it with fluid until I can get it back to the dealer. As I recall from last time this happened, you can't just walk in to autozone and get the fluid that LR uses. Any thoughts on how to limp by for the next 48 hrs while I do some around town driving? thanks in advance.
horns
Pentofrost SF - found at O'Reily's - in case anyone else has the same problem in the future.
eljefe
great info. I would just put some water in if I was in a pinch. distilled if possible. but that is me.
