LR3 Rear Light (drivers side).
land crzy
Question?
Has anyone removed the rear light assembly from 05 LR3 for either bulb replacement or tow package upgrade?
drzjoint
Open the lift gates and you will see screws philips or torx can't remember. Remove them and pop it out it is also explained in the manual.
Boaz
Very easy. I've removed them to install the rear lamp guards. Two phillips screws on the inside. As mentioned, you just lower the tailgate to get at them. Then just get a good grip and pull straight away. There are two "plugs" that just pop in and out behind the lights. Doesn't take much pressure to pop them out.
