Magnaflow Cat Converter
D
discoskc
Has anyone used a Magnaflow Cat Converter? Is that a good replacement Cat? Would you know the part# that would fit a 95 Discovery?
A genuine Cat from AB is like $700.00. Hence the thought of putting on a Magnaflow Cat.
My original Cat is rattling like crazy. From my research it seems like I will have to cut the existing Cat from the Y pipe and then connect the Magnaflow to it (maybe weld)?
Is my understanding of the process correct?
Sergei
Mike, its wrong one.
Unfortunately looks like 94-95 were blessed with 2" ones.. How i found out? B/c i still have pair of 2 1/4" ones sitting in my garage, and completeexhaust people cant be bothered to send me RMA for 4 months.
You need 9004 series cats, 2" diameter. they are ok.. Still pain in bottom to fit. But ok.
D
discoskc
Thanks Sergei
Sergei,
Thanks a bunch for that info. Is my understanding of the process correct though?
Cut the existing cat out. Then weld the new one in?
Sanu.
Paul p
