New ceiling liner
T
Tec3394
Hello, I have a 1995 Discovery and the ceiling liner is really dirty and it is too much toi clean because it has grease all over it from fixiing the sun roofs. i am looking for the cheapest place to get one or anybody who is selling one. Thanks
Slam
Supporting Member
Supporting Member
Check roverparts.com. Let us know where you find one, because I think I might replace it too.
D
disco1
A new ceiling liner is not an easy fix. The whole roof liner has to be removed and replaced with new material usually by an automotive upholsterer.
B
bendrover
I've looked into this with regards to upholsters, they tend to work for about the average of $300 if the body of the original liner is intact. They can repair minor hole damage usually. It's a great idea. Call around in your area.
Andrew
T
Tec3394
I found them on Ebay for about $150.00, it think. but i cant remember if it is for a D1 or a D2. Is there any difference between the headliners in the D1 and D2?
Slam
Supporting Member
Supporting Member
There is a difference between the d1 and d2 liner.
D
disco1
I wouldn't use carpet cleaner on it, but upholstery cleaner will work. The only problem is that eventually, if it's used too often, it will cause the headliner to sag.
PE_in_UAE
