New Suspension (shocks & springs)
W
wmg1971
Hi all,
Can anyone advise on which shocks & springs I should be looking at to replace the stock system? I have 50K miles on my 2000 Discovery and compared to other models, the space between the top of the tire and the bottom of the wheel arch is a lot less...Can I go with Monroe shock and a heavy duty spring from a good manufacturer? I do some off-roading from time to time here in Nevada, but I mostly drive on the highway to and from work...Any help would be greatly appreciated...Oh, total costs to purchase and install would be nice also...
Thanks!!!!
Warren
D
disco1
Once again opinions will vary. Here's what I did when it was time to change my original sagging springs. I installed a set of heavy duty springs (no lift) all round. For shocks I run Bilsteins, standard Bilsteins on one of my discos and a 30% pressure increase (over standard) on the other. I do a lot of off roading and have found these combinations quite adequate. I hope this helps.
W
wmg1971
Which manufacturer for the springs you decided to select?
Thanks for the reply!!!
D
disco1
The springs are custom made by a very small spring manufacturer here in Sydney Australia, called Universal Springs. Sorry I can't be of more help.
S
Seth
I recommend Rovertym springs. I'm running them on my D2 and am really pleased with the ride, the articulation and the lift height.
www.rovertym.com
Seth
STQAddie91
