Oil Pan gasket
ColorofKris
2003 Disco II 4.6L with 99600 miles (just saying)
Hey was looking to change out my oil pan gasket, my grandpa is a retired mechanic so hes gonna give me a hand replacing some of my bad gaskets. I have been researching and have seen alot of people say you have to lift out the engine a bit in order to get the pan and gasket and such out. Ive tried researching this more but couldn't find out why? I have a 3 in lift on the disco and also 2 inch cross member spacers on the cross member that runs under it. Would either of these help my cause? if not what is it that's in the way? On that note as well, what is some general advice about doing the gasket that would be good to know? I would appreciate the help thanks!
CBRacerX
Subscribed. I'm about to take on this job also.
The engine does not need to be removed.
Make sure you clean out the pan/sludge and pick-up tube.
PE_in_UAE
