P0734 Gear 4 ratio incorrect, 2000 D2
R
RhodeRanger
Hello all, Just jumped on rover world to check out some tech about a disco2 I'm working on for my g/f's sister.
On the 2000 D2
had a couple codes
P0447 -EVAP vent circuit open - Fixed - reconnected plug to vacume solinoid in engine compartment passenger side behind battery - the last mechanic left it off! Engine light is off now!
Second code P0734 = gear 4 ratio incorrect.
Anybody know what that could be? She doesn't note any driving quirks - but its also her first automatic trans so she doesn't know what wrong would be..
Also, I see there is no trans fluid dip on the D2, how can the fluid be checked?
And tips are greatly appriciated,
thanks
Moose
Some guys will not check in till tonight or tomorrow...try waiting more than 27 hours for your answer....
This code is a common one that points to an MAF error. Try cleaning the MAF with electronic parts cleaner?
R
RhodeRanger
Thanks for the tip, next time I see the vehicle in my driveway.. I'll give it a blast!
- i had found somewhere that the generic code reader was not absolute, and that code was a MAFS code.
I looked at the MAFS that day, theres a plastic mesh over it that looked a bit scuzy, as did the filter - this disco needs a little PM.
yeah, well, I'm a bit spoiled from TheRangerStation forums!! sorry.
RoverChic
I love Ryan and Rovers
There is not a tranny dipstick on the D2. I have some info that can be sent to you via pdf if you want more detailed info on how to check it. It is a real pain in the ass..Sorry for the harsh words but that is the truth.
R
RhodeRanger
RoverChic said:
There is not a tranny dipstick on the D2. I have some info that can be sent to you via pdf if you want more detailed info on how to check it. It is a real pain in the a$$..Sorry for the harsh words but that is the truth.
Yeah, I figured as much, its proabaly similar to the VW Passat we have - its like a bently transmission. Fun
Thanks for the offer, but I won't have to check it - its not my vehicle.
And by the way they maintain it - I'm staying clear of it...tic tic tic BOOM.
Cleaned the MAFS - it was crusty - didn't clear the code _ the filter needs a change too.
Valve cover leaks oil, checked the level - ....was 2.5 qts low.. Yikes.
I made some suggestions - i hope they take the it in for some service..
Poor disco.
STQAddie91
