Persistent fault codes - Disco 96
carehta
My D1 has about 145k and is giving me a hard time on P1371 P1373 (early ignition coil activation). I have replaced all coils, all wires and plugs. Have had the LR dealer bleeding my pocket just to confirm there is nothing wrong with these parts. OK, there was a crankshaft sensor loose, but it is now corrected. The harness ECU-coils have passed continuity test. They asked me to consider the ECU replacement! Sad enough, they do not warrant it will do the trick though. So I can end up with two beautiful ECU in working condition with a truck on misfire! Not intending to be an ECU collector, I'm after all possible advice I can find. Can you guys help here: is there anything else you recommend me to do? :confused::help::ahhhhh:
Go to the Rave CD and read the testing procedure for those coil faults, pretty easy to do.
carehta
BTW pal would you mind in pointing to the RAVE chapter for the testing you suggest? The RAVE I have downloaded new does not have anything on testing. Appreciate your patience here.
Paul p
