power window
gotmullet
need advice
my drive side power window does not roll down. here is what i done.
1. remove panel and reconnect the window harness
2.when i press down, i hear the motor click.
3.remove the window motor and here is the interesting part. the motor only move in one direction. when i press up (if you looking down on the motor) it turning clockwise. if i press it down, it still turning clockwise.
Can i assume the window switch is bad?
tlt
It sounds like the switch, i've heard others report switch issues. Perhaps you can test it with a multimeter if you remove it.
EIGHTLUG
Try swapping the harness over to another switch on the door panel, like the passenger window switch and see if the symptoms are the same.
PE_in_UAE
