qadhafi
- Joined
- Jun 30, 2004
- Posts
- 49
- Reaction score
- 0
Prospective N00B .....*But I'm getting better*
Hi all, I hate to duplicate Wh00t's thread but I have some questions also and didn't want to jack his thread. Let me open up with the fact that I know nothing about Discos but I'm learning more and more every hour. I found your forum to be the most apealing becasue you don't skin your noobs alive and you try your best to answer any questions that they may have. I'm a regular on a couple of Jeep BB's so I'm going to try and make this as painless as possible.
Background:I currently reside in Rome, GA and I own a '94 Jeep YJ. <--- Clicky. I run a Jeep club with a buddy of mine in VA and we currently have three chapters. I'm pretty good with a wrench and can do basic repairs (oil change, tune up, cooling, lighting, stereo, suspension) but I've never done anything major (axle swaps, engines, trannys).
Looking to buy: A Late model (2000-2002) Discovery II for use as a Daily Driver + some offroad use. Price range is 11k-15k and I've found quite a few around here. I'll be holding on to my Jeep for trail rides etc. but would like the Disco to be capable if I needed to recover one of my idiot friends (or myself
). Plans would be a 2" lift or so and some MT/R's (along with scraping the soccer ball off of the back window). Don't be worried though, I personally guarantee it will see mud. (I can't stand 4WD vehicles that don't offroad, what a waste).
Questions: I've already read wh00t's post and I know to look for Gremlins (which I am assuming are electrical shorts) and the O2 sensor (How do you check an O2 sensor?). Is there anything else major to look for?
A few more things: My brother in law is convinced that Discos come with ARB air lockers in the front/rear diffs standard. From what I've read I don't think that this is true. What is a locking center differential? It may jsut be a technical term that's not translating. Jeeps have a vacuum shift motor that engages the front axle, is this similar, or something totally different? I have read to make sure that it will shift, and to check the linkage, but is there anything else to look for in the 4WD system? I've read about the Hill Descent Control, but is there supposed to be another traction system on these trucks? (Or is Land Rover trying to call 4WD something else?)
Axles: Is either axle known to be weak? The reason I ask is because the Jeep Wrangler rear axle (Dana 35) is known to be the weak link in the drivetrain. I am also assuming that one could install sway bar disconnects on the front axle for artriculation.
Thanks for reading all of this, I really do appreciate any help that someone might give me on this. Hopefully I'll be coming over to the Dark ...I mean Green Side
soon.
