Hello,
i have a range rover 4.6 HSE, wo will no longer run.
There is no firering up on the sparkplugs, there are different messages comming on the dashbord "Doors open, Roof open, Engine locked,....." and manny more.
Al happend after a leakage from the cooler, the wiring under the hood was wet.
Ok, all "Error Messages are gone" and the next problem is arrived.
Display message "Engine Locked" - "Press Unlock Key" after i do so it says "Engine Start", when i turn the ignition key nothing happens no cranking, so also no firing.
All fuses checked and they are OKE.
So i'm at the end.
On the passenger drivers side (Eurpean Version) i found a totaly oxcidated connector (green oxcidated water) wich goes to the
Body Electrical Control Mod-ule (BECM), so that thing is to repair first.
BECM box is dry, no water or anything else, all cable connections OK.
I repaired the connector, i have shortcuted the startmotor and it was crancking and again no firing, petrol pressure is oke.
Somebody any idea, where to look next.
So i'm at the end.
