Really good coolant leak under the engine!
James Green
Corona, CA
Hello all. I could use some help. Noticed a big pool of coolant under my 2007 LR3 4.4 today. I recently re-routed the rear coolant lines in the rear passenger wheel well to accomodate larger tires. I thought I sufficiently bled the air out of the system before closing it up, but I suspect this new found leak must be related to that modification. If I left too much air in the system, could it have damaged/popped a seal or a hose or something? Water pump failure? Any input would be greatly appreciated! I'm a newbie. Thanks. (seems to be dripping really good from the bottom of the part circled in the pic below but hard to find the source since there is fluid everywhere!)
James Green
Corona, CA
I see coolant dripping onto the TOP of the water pump. I think it is safe to safe it is the plastic thermostat housing that has failed right? I don't see any other hoses or fittings that seem to be the culprit.
douglastic
Just making sure you checked the problematic bleeder T valve (under top engine cover)?
They break quite often when old. I swapped mine to brass after it broke.
James Green
Corona, CA
Yes, thank you. I actually already had that adventure and I'm running brass. In the process now of removing the thermostat manifold now. Quite a process! Seems more difficult than the water pump
James Green
Corona, CA
Replaced the thermostat manifold and water pump. No more leaks! That I can tell. That's a win for me. Now however, the dash is FULL of faults... Transmission, HDC, Parking brake, low coolant. I tried to clear any error through my cheap OBDII scan tool and disconnected the negative battery terminal for a couple minutes but the faults remain. I have good volts at the battery. Any other suggestions?
James Green
Corona, CA
Update! I thought I pulled the fuse for the parking sensors but I pulled the one right above it. The numbering on the fuse panel threw me off. Putting that fuse back, I am error FREE and leak FREE. Good times.
16RRSportjyn
