rear window
connor
:mad:
ok here's the prob.
I had just put the convertable roof on (because it was boiling) and i left the rear window down.
I had a bbq and I came back to park it in the garage (it was outside my house) and the rear window would'nt go back up!!
If anyone has ANY help or tip's then please reply and help my!!:biggrin:
thanks
On a freelander, I would start by checking fuses and then the switch.
E
ecmoney
:mad:
ok here's the prob.
thanks
rear passenger window?
this is a big problems for Freelander, I had to fix mine last year.
It's the rear window regulator
costs about $300-$400 for the part alone
C
castolfo
rear window issue?
no disrespect intended here to other post'ers..
i have a hunch that before you go and drop 400 bucks at the stealership, disconnect your battery first (assuming that the rear window is down).. the calibration may self correct when you re-connect...
let me know if it works..
