Rear wiper issue
RAJOD
After going through a car wash I noticed my rear wiper was pointed down, it was on the painted part of the rear gate.
When I grab it I can rotate it freely, I could feel no centering lock to put it where it should be.
I put it where it should be but after I use it, it seems to creep to where its wiping the tailgate and not the window.
Is there an adjustment?
RAJOD
I fixed it.
Called a LR dealship and got some instructions. Was EZ.
The rear wiper was below the glass and I could move it freely with my hand.
If I put it where it should be it gravity would just drop it down 30 degrees or so.
The fix was to remove that black cap and then put a socket on the bolt. I put the wiper where I thought it should go and gave it a 1/8 turn.
Seemed to fix it. I don't think there are any splines holding it. It seems to be just a friction fit. Which I guess is good, it will give way if something torques on it.
I could grab it now and still move it to a new position. I think the large nut probably loosens over time.
No need to tear the car apart to fix.
PaulLR3
Boston
I have a different issue, apparently road salt and grime built up in that riveted joint, so there is minimal wiper pressure against the glass. I tried cleaning and lubing it but after a few days it stays away from the glass. I imagine the spring inside the arm is fatigued from fighting the stiff rivet joint all winter. Time for a new rear wiper arm.
