RR p38 2.5 DSE - new member need a Help !
koni
Hi,
I consider buying Range Rover p38 with the diesel engine 2.5 -and I can't find the whole specyfication of this model.. that's why I'm asking for help. If anybody has information about this engine and whole car please send my them to [email protected]
thanks for any help
Koni
PS. I need something like that
Range Rover 4.0/4.6 (US Spec)
Dimensions, Weights and Capacities
Length 185.5 inches
Width 74.4 inches
Height 71.6 inches
Wheelbase 108.1 inches
Track 60.6 inches front, 60.2 inches rear
Turning Circle 39 ft
Ground Clearance 8.4 inches
Fording Depth 21.3 inches (hi profile)
Approach Angle (Hi Profile) 34 deg (spoiler on), 37 deg (spoiler off)
Departure Angle (Hi Profile) 25 deg
Breakover Angle 29 deg (Hi Profile)
Luggage Capacity 31 cu ft (rear seat up), 58 cu ft (rear seat down)
Curb Weight 4,730 lbs (1995), 4960 lbs (2001)
GVWR 6,130 lbs
Payload 1,400 lbs (1995), 1160 lbs (2001)
Max Roof Rack Load 176 lbs
Max Trailer Wt 6,500 lbs (with brakes), 1,650 lbs (without brakes)
Max Tongue Wt 550 lbs
Fuel Capacity 24.6 US gallons, deformable fuel tank & pump intake
Engine Data
Engine Type 90 deg pushrod aluminum V8, steel cyl liners, cross bolted main bearings
Displacement 3950cc (4.0), 4554 cc (4.6)
Bore/****** 3.70/2.80 in (4.0), 3.70/3.20 (4.6)
Compression Ratio 9.35:1
Power (1995-98) 190 hp (4.0), 225 hp (4.6) @ 4,750 rpm
(1999- ) 188 hp (4.0), 222 hp (4.6) @ 4,750 rpm
Torque (1995-98) 236 lb-ft (4.0), 280 lb-ft (4.6) @ 3,000 rpm
(1999- ) 250 lb-ft @ 3,000 rpm (4.0), 300 lb-ft @ 2,600 rpm (4.6)
Engine Management sequential multiport fuel injection; Lucas to 1998, Bosch Motronic 5.2.1 from 1999
Ignition System Distributorless 4 coil direct ignition w/2 knock sensors
Alternator 150 amp
Fuel Premium Unleaded
Drivetrain Data
Transmission ZF 4 speed electrically controlled auto w/locking torque convertor
Shift Modes Normal, Sport (hi range only), Manual (lo range only)
Transmission Ratios 2.48, 1.48, 1.00, 0.73:1. Reverse: 2.09:1
Transfer box Borg Warner 44-62 chain-driven, electric shift w/viscous locking differential
Transfer box ratios 1.22:1 (hi), 3.27:1 (lo)
Differentials 3.54:1 ratio spiral bevel diffs. 4 spider gears on axles with traction control
4WD type: Permanent 4WD
Axles Solid axles, fully floating hubs with both differentials in line on one side
Traction Control: Rear wheels (1995-8), all wheels (1999- )
Wheels 16x8 inch alloy (4.0), 18x6 alloy (4.6)
Tires 255/65R16 (4.0), 255/55R18 (4.6)
Brakes 4 channel ABS, swept area 469 sq in
Suspension
Front: Rigid axle located by radius arms and Panhard Rod.
Electronically adjustable air springs
Anti-Sway Bar
Rear: Rigid axle located by Panhard Rod and composite radius arms
(radius arms designed to contribute some roll resistance)
Standard Appointments
Heated outside mirrors, programmable 2 position memory; tilt down when reverse selected
Heated windshield w/heated washer jets
Heated rear window w/power wash and intermittent wipe (automatically activated in reverse
w/front wipers on)
10 way electrically adjustable heated front seats w/2 position memory
One touch open/close front windows & sunroof ;
One touch open rear windows
Automatic dimming rear view mirror
Automatic dimming exterior mirrors from model year 2000 on
Audio System: 120 watts, 11 speakers (300 watts/13 speakers from 1999, 300 watts 12 speakers 2001 SE, 460 watts 12 speakers 2001 HSE), 6 disc CD changer, 2 fm bands, am band, auto seeking weather band, cassette player, speed equalization (2001 HSE)
Automatic climate control w/separate driver/passenger side controls
Outside temperature gauge
Pollen filters for sealing out off-road dust
Flush mounted mudflaps (standard on 4.6HSE, optional on 4.0)
Dual halogen headlights w/power wash & wipe; auxiliary fog lights front and rear
Puddle lamps front and rear
Cruise Control
Tilt/telescopic steering wheel, collapsible steering column
Driver & passenger airbags
Security system with keyless entry
Integral Class III trailer hitch receiver
Leather seats with adjustable head restraints front and rear
Leather and burl walnut trim
Message Center w/150 messages about all vehicle functions
Trip computer
Child locks on rear doors
Home Link system for garage doors and security gates (optional to 1997, standard thereafter)
Performance Data
4.0SE (Car & Driver, April 1995)
0-60mph 10.5 sec
Standing 1/4 mile 17.9 @ 77 mph
Top Speed 113 mph (Car & Driver), est 116 mph (Road & Track May 1995)
EPA city/hwy 13/16
Observed fuel use 14 mpg (Car & Driver)
Braking 70-0 185 ft
Skid Pad 0.73g (Car & Driver), 0.76g (Road & Track)
but for Range Rover 2.5 DSE
