Self Leveling Relay 2004 LR Discovery
MikeF
Hello Disco fans,
I have a 2004 Land Rover Discovery S7. When I was going through all my fuses under the hood I noticed that the two "relay boxes/switches" that are labeled (with a picture) self leveling suspension relay and the one right next to it with the "other" suspension related icon are missing.
Does my "S" model come with that/those features and someone maybe just removed them (IE: my model is capable but since relay isn't there I'm clearly not getting the benefit? And second question:
I'm going to order a scanner to find out what the 2 faults are for the check engine light and I see that most scanners (reasonable priced ones) cannot interpret Land Rover codes if anyone knows of which scanner will work for my vehicle. Also, the three Amigos come on every other day and do these scanners check for those faults too (ie: do I need a different type scanner for those problems b/c the scanners that I see only check engine/transmission fault codes)
thanks guys, Mike
I doubt your "S" model has SLS, rear air suspension, that is why you don't have those spots full.
Paul p
