SLS not working??
S
swrye
Hello,
I am a new Land Rover Owner. I just purchased a 2000 Disco II with the SLS option. My problem is that it was working just fine yesterday but has stopped working. Even when I push the manual button, the light on the dash flashes like it is working but nothing happens. The light just keeps flashing until I turn the engine off. Checked the obvious and the fuse is still good. Not sure where to turn. Any and all help would be greatly appreciated...
Thanks,
Seth
S
swrye
SLS not working?? FIXED!!
OK... Apparently the fuse that I checked only controled the sensors and the switch. After poking around I found the second fuse box in the engine compartment and found the 30 amp bus fuse that controlled the pump. Replaced and it is fixed!!!
Thanks,
Seth
Rome0Mike
