Sos!!mystery Leak_help
F
fdbandit
Was cleaning my 2000 RR and discovered that the rug on the passenger side front was soaked. Could not find a leak anywhere and not sure but I think the liquid isn't water. Can anyone direct me and help figure this out?
Thank you
Chic Cieslik
E
Ebooters
hi sounds light a/c drain tube blocked it you climb under car look up at the floor just above gearbox bell housing you will see 2 rubber caps these pull out you need to clean these out and then push back do this when exhaust is cold cheers carl
