sporadic coolant leak
rjwil90
My wifes 03 disco leaks about a quart of coolant, but only sporadically. The coolant appears to come from the right sided of the engine compartment. I have replaced the thermostat and bled the system of air. Worked fine for about a month, but is doing it again. No signs of overheating. The heater also operates intermittently when on the hot setting.
Do not let this go on any longer. Go have your mechanic pressure test the coolant system so you can find and fix this leak before it damages your engine.
strally
