Steering gear box, oil/trans cooling lines leaks...
Zende
95 Disco 140K
Just picked up my truck from the shop.
While it was on the lift the mechanic pointed out where my leaks are coming from and told me it would be very expensive to fix and eventually my steering would go out..
Problems..
Steering Gear box leaks + hoses (do i need a new gear box or can I replace seal?)
Engine oil cooling lines leaks
Trans cooling lines leaks
Can anyone tell me how serious this is and if its worth replacing all of this for a few leaks?
Thank you
Most of these lines you can have made at any hydraulic shop for about $100 total for all. As far as the leaking steering box, buy some Lucas transmission fix and add to the PS fluid. Remember the LR takes Transmission fluid not PS fluid.
