Steering
Shmelton
I'm getting a shake, or shimmy in the steering wheel when Im running between 60mph-70mph. Just had new tires put on, also ABS light is on. What could be loose that is causing this?
Welcome to the forum... what year?
Assuming this is a D1, Panhard rod bushings or front hub bearings are loose.
ABS light could be a dirty or bad ABS Sensor.
Assuming this is a D2, Panhard rod bushings or front hub bearings, Ujoints in front drive shaft, ball joints.
ABS light could be a dirty or Bad ABS sensor, ABS modulator needs grounded, fluid is dirty...
Shmelton
Sorry it's a 97 Disco 1. I will look into that and see if it fixes her. Thanks for the info...
Paul p
