Suspension Fault
caimbo
On way home car started bumping along as if there was no damping
Display then started showing suspension fault and keep to 50km max
When I got it was sitting on the bump stops
caimbo
Bit more info - its a 2006 RR Vogue SE with 124k on clock
Cant find the search tool on this site (new user)
Air pump or bad air bag that cause an air pump issue. With the mileage listed I would say replace both just to be safe.
caimbo
Dealer called and tells me both front shocks have leaks in the airbags, $2200 AUD each for LR parts plus labour or he can source pattern parts for $700 ea from UK, told him to go ahead and order the pattern parts
agoritsk
I replaced my front struts, both last week. Had an issue with the rt side, but just replaced both.
2008 HSE with 122k miles.
625$ each air strut from atlantic british (Delphi) and then 400 to install both... seems like a good deal compared to the dealership.
caimbo
Job done, $300 to fit at local dealer which was decent
Total $1800
Would have been $4700 otherwise with LR parts
PE_in_UAE
