TC, DHC, ABS light came on
hector RIvera
hi greetings everybody
mine is Land Rover discovery II 02
I got these 3 leds on the TC, DHC, ABS if some body could give me a suggestion
of what I can do. Beside taking it to the shop and hook that machine to test it. which I know it will cost me a fortune.
I am taking this trip to las vegas with my family from California and I am not sure if it would be good idea to drive with this LED'S on. Advice please.
thanks
Disco Squared
If these lights come on intermittently after driving for a while, and you have squeeky brakes, changing your brakes/pads with quality parts can fix the problem. If the lights come on immediately after start-up, it is a hard fault code, something is wrong with the ABS system. Sometimes a wheel sensor lead will come loose, its worth checking all the wheel sensor connections to make sure they're tight before going to a mechanic.
Paul p
