Top Engine Rebuild
Red Top Engine
Pittsburgh
Hello! I'm new to this site. My newly purchased LR4 hesitated to start and ran rough for 2 min before stalling. I suspected fuel pumps (all three) and timing chains- replaced all,only to discover symptoms remain minus timing chain slapping noise. I should have done a compression test before timing job. Turns out I have no compression on either cinder 2,4,6,8 (all on drivers bank side) and between 120-150 on all passenger side cylinders. I suspect the valves are bent and need replaced which is what I am going to do. Has anyone removed heads off the 5L V8 while in the car and had a valve job done?
PE_in_UAE
